Re: What are these two hinged items next to my outboard?
Hell's fire! If you have it then the thing ought to work. One of the things in the water, the pickup for the speedometer, is just a thing that siticks down in the water with a little hole in the front. It picks up water and runs it through a 1/4" tube to the dash where it plugs into the back of the speedometer. What the speedometer actually measures is water pressure.<br /><br />There is another type of speedometer too. With this one the thing on the back would have been a bracket to hold a transducer that had a paddle wheel. As the wheels spins with speed it sends back an electrical pulse that can be read by many machines and displayed as speed. The pulsecount per mile traveled is agreed to by standard, so they are all the same. <br /><br />When the word Transducer is used it is usually in conjunction with a depth finder. Its the part that makes the outgoing "Ping" and listens for the return echo to send a signal to the display unit, up on the dash, which will then interpret the signal and paint a recognizable picture of a screen if that is the sort of machine you have,<br /><br />If I were you I would replace both and do whatever else it took to get them working. I'd do the speedometer just because its sitting right there on the dash staring at you, and it would drive me plum nuts looking at it if it wasn't working, The depth finder just because I think every person operating a boat should know where the bottom is relative to the boat at all times, but particularly when in shallow water and even more so when opperating at speed. It is simply a matter of safety even if you don't fish or have kids who will marvel at the picture of the bottom.<br /><br />Thom
