Where to lift a mercruiser 120?
Flyin1500
Howdy,
I'm in the process of removing my 1984 mercruiser 120 engine. Where do you lift the motor from? The head has the forward lifting point which is pretty obvious, but what about the other lift point? Or is it just the one. Thanks!
old islander
Re: Where to lift a mercruiser 120?
Look behind the valve cover, top of bell housing area. You should find a second lift ring. If not, remove a bolt at the top of bell housing and install a longer bolt through your chain there. use a hardened bolt, not a hardware store cheap-o.
