Last August i bought a 1991 bayliner capri with a 120hp force. I ran it for 2 months and ran very well, we had fun with no issues. When I removed it from the water in October I replaced the starter and had it "winterized". I have been working on getting it ready for this summer, as I baby most of my things, I put a new blower unit it, a dual battery system, replaced the lower exhaust as it had a hole, and changed the oil on my leg ( which had a leaky seal and water in it).
I went for my first water test yesterday and after a few attempts it started fine but didn't stay running long. I did have fast idling problems last summer and hard starting. I think I need to adjust the idle screw so I am not overly concerned unless someone thinks I should be?
My real issue I had was when the motor was running I saw water bubbling up from what appeared to be the engine mount and some smoke coming out of the engine compartment. I understand it's an old boat with a 2 stroke which will smoke.
Does this make sense? Does anyone know what the issue is? I don't mind spending some money on this but will only go so far as I bought it cheap hoping to get as many summers as I can out of it.
