country cadillac 48
- May 14, 2013
- 33
My 79 70 hp Merc serial # 5352753 still has no spark to #3 cyl. but I think I'm getting closer. I switched #2 coil wires with #3 and the problem moved to #2 cyl . I moved them back the way they were and checked the voltage from the switch box to each coil at idle, #1 read .08-1.00 volts, #2 read .07-1.00 volts and #3 read 0.00 volts. I don't know what the readings should be and I don't know which one or both need replacing.........but I know group of fellas that do know......again..I'd really appreciate your help................thanks ...Ray
