jumpjets
- Nov 11, 2010
- 313
I accidentally ran my engine for a minute with the muffs on, but I forgot to turn on the hose. It was only run for a couple minutes like that. I let it cool for a few hours, and ran it again. As it was running, there was no water flow exiting the engine from the prop hub or the 2 exhaust ports on the transom. All the water was just gushing out the sides off the muffs.
I pulled the impeller and it is a melted mess. I'll replace it tomorrow. The exhaust manifolds were hot to the touch, and the temp gauge got up to 220. The oil is still clean, so I don't think I warped a head. Time will tell.
Is there anything else I should check? Is there anything else I should definitely replace besides the impeller?
