Fleetwin
- Nov 23, 2011
- 1,141
Hello All,
I am looking to by a 2009 boat equipped with a 3.0L GL. Sorry, no Serial number. The engine has 20 hours. Sounds and runs great.
My questions:
1. There is an exhaust bellows (I believe) that goes from the transom assembly to the outdrive. It can be seen from the side. I think there are two bellows, one for the driveshaft and the lower one for the exhaust. correct? This one has a small leak, on the bottom, toward the front, near the clamp. At least I think that it is a leak. How hard is the bellows to change if it is leaking?
2. Will that cause an issue if I run it for a while like it is?
3. I also noticed that the 3.0L Volvo is much louder, on the muffs, than a 3.0L MerC. There seems to be a lot of exhaust coming out of the rear of the cavitation plate. Normal?
4. I believe the Volvo to be a superior drive. Anything to look out for?
Thanks!
My questions:
Thanks!
