omc350 just built
jack z
I just built my first motor. Having problems withover heating. Idle and running. Help please
southkogs
Re: omc350 just built
What year OMC? Are you running on muffs or on the water? Did you change the impeller?
jack z
I did not change impeller. I looked at it and i nelieve it os fine all teeth are there amd appear to be on good shape.
jack z
1988. I was in lake woth the boat,fresh water, i beloeve timing is right
jack z
I believe the water pump is functional. The carb I am not sure about. engine timing should be right I believe
Nivekt
Did you rebuild the carb before putting the motor back together? How long has it been since the last rebuild? Always a good idea to rebuild your carb if you are building a new motor or if its been a few years. Dont guess on your engine timing either. Go to your local auto parts store and rent a timing light and KNOW the timing is right.
Also, are you using fresh gas? How long has that gas been sitting in the tank since last fill up?
