classiccat
"Captain" + Starmada Splash Of The Year 2020
- Dec 20, 2010
- 3,405
I recently pulled the powerhead off of newly acquired 70573B after discovering that my exhaust housing was bent (replaced the ext. exhaust hsg).
With the powerhead off, I figured that it would be a good time to check the exhaust/head gaskets & add a tell tale.
Exhaust manifold had alot of deposits and some corrosion. Cyl#2 had a water leak into the exhaust port (It may have some pitting on the baffle plate gasket surface...still cleaning gasket residue).
I pulled the cylinder head last night and found some light scoring in Cyl#1...along with dings in the piston & cylinder cover...it looks like something came-in through the intake and bounced over to the exhaust.
The score mark is very light...barely feel it with your fingernail and the engine has excellent compression...in fact, cyl#2 is a tad lower (139, 132, 138 on 1,2,3 respectively). Rings also look fine from the exhaust-side.
Leave good enough alone...watching for a performance/compression degrade???
If she had questionable compression, i'd already be ordering a new piston/rings and finding a marine machine shop...but strong compression has me puttin' the brakes on a total tear-down.
Thanks guys!
Thanks guys!
