Clark in Michigan
- Sep 12, 2010
- 13
The boat.... 1979 Tiara 2000 with a MerCruiser 898.
The problem... Backfire thru the carb after trolling (for hours).
Runs fine on the way out, runes fine trolling all day, get ready to head back in runs like crap.
Backfires thru the carb so bad i cant get more than 2000 rpm.
Things that I have tried... Rebuild carb, checked all fuel lines and water separator, SEVERAL sets of points, caps, rotors.
SEVERAL sets of new plugs. New plug wires. Have set the timing 8 btdc. Have set the points with feeler gauge, have tried with dwell meter. Nothing helps same issue every time!
Yesterday on the water I hooked the timing light to several different cylinders and noticed that the light was not consistently flashing while the engine was in gear and at 700 rpm. What would cause it to not spark consistently?
I have no idea what to do next...
Coil?
Electronic ignition?
Any ideas????????????
Thanks
Coil?
Thanks
