Ok so, I'm 4 hours from home with my pontoon boat , my engine service manual is at home.
Engine won't idle worth flip. found #3 coil will never fire while turning over with starter.
I swapped power/signal from powerpack #2 cylinder grn/wht-middle cylinder coil wire with #3 cylinder grn wire.
No spark at number 2 cylinder now, so my coils are good.
The spark from other two coils is very powerful.
My main question is about the signal to powerpack,
Can I swap these trigger wires to the powerpack to confirm problem is from stator or a dead output on powerpack.
Would be really nice to know before dropping $200+++ On a powerpack.
Powerpack wiring From my taxed memory:
the red/blue/black-yellow is power/power and kill respectively.
Then I have the 3 green coil wires (coil primary inputs)
That leaves the trigger wires to powerpack, which is what I'm thinking I might could swap around to confirm where problem is. The wires are blk/brn/wht/wht-blk.
Is this possible? If so which of these can I swap.
Any help greatly appreciated.
