I have a Yamaha 225 VMax outboard (V225TLRX). The engine started giving me problems two weeks ago. It ran fine out of the water but stalls under load. In the water It would idle fine, at WOT it would be fine for about 2 minutes then it would loose power down to 1000 rpms. The problem got worse and worse to the point that it wouldn't pass 2k rpms before loosing power and stalling.
I replaced the fuel filter on the motor and the inline water separator filter. I also inspected the VST filter and it was clean. I replaced the plugs and took her out again today. Now it will not make it to 1500 rpms without stalling. I checked the plugs and they all have spark although they seem weak. No water in fuel.
Now it won't start at all, even out of the water.
