Hey every one I picked up another 89 150 and got a set of carb bowls off eBay aluminum ones to swap. My carb sizes are different the jets inside the plugs on the side of the bowl are the same but the small jets inside the bowl are not. Mine were 29c and the aluminum came with 33 and there completly different sizes. Before I order new 29c jets for it. Will the 33 work? I feel like the engine could use a little more because its not as peppy as my others and compression timing and all that is good. Well the bigger jets be ok or should I just hold off for the 29c to be ordered?
