Prop for 40hp Mercury 4-stroke not bigfoot
dsleep
I have a 2002 Fisher pontoon with a 40 hp 4-stroke EFI, would like to change props to a Solas 4 blade, what size prop would be best for this motor and boat?
jestor68
Re: Prop for 40hp Mercury 4-stroke not bigfoot
Provided the motor turns within the recommended rpm range(5500-6000) with the current prop, it is recommended to select a 4 blade of one inch less pitch in order to maintain rpm. :)
steelespike
Welcome,what size pontoon?
Have you run it with the present prop?What size is the prop.(usually under the prop nut).
What is the wot rpm and gps speed.
dsleep
It is a 20 foot pontoon, and I am getting 5800 RPM with current prop, will pull off nut today to get current size, it's not on the blade so must be under the nut, thank you both for your quick response....
steelespike
Would help to have your wot rpm and speed,preferably by gps.
dsleep
My wot rpm is now 6000, no speedo or gps, got the prop off and the only numbers found are Michigan 032141, found not under the nut but on the back side of the prop on inside washer, best I can measure it's a 12 inch prop, prop decal on motor is scratched off only number you can read is 13 which I believe is the spline number.
steelespike
Your present prop is a 12 1/2 X 8" 3 blade.What is your speed some cells have a gps app.
Why did you want to try the 4 blade? I don't see a Solas 4 blade here but there is a Michigan Vortex 4 blade at a competitive price.
If your making a good strong 6000 I think you could stay with a 8" 4 blade. probably put you at about 5900.
dsleep
Was hoping to get more control with the 4 blade prop, just upgraded pontoon from an 18 footer to a 20 that's heavier and less responsive in the wind with the top up, also built a boat house and would like more control trying to get it into it's slot....
steelespike
A 4 blade should give better control around the dock.How much it can respond against the wind remains to be seen.
dsleep
So are you saying to go with a 12 1/2 " x 8" x4 blade prop, in other words keep the same pitch? As opposed to the other advice to go with 1 " less pitch to get the same RPM's.
steelespike
Yes I'm thinking if you have a good strong 6000 rpm you could stay with the same pitch lose 100 or so and maintain your speed better than dropping an inch of pitch.Just a hunch.
dsleep
Sounds like a good plan so to be sure I'm looking for a 12 1/2 " x 8" x 4 blade prop correct ?
steelespike
Don't fixate on the diameter a 4 blade may be slightly less diameter. if you have a choice of diameter get the larger one.
dsleep
Thanks I appreciate everyones help, thanks Mariner......
