Nivekt
- May 13, 2009
- 481
My dwell meter wont give me a dwell readout when cranking the engine with my remote starter. I have all the leads removed from the - side of the coil. The green from the dwell meter is hooked up to the - and I have the black/ground lead of the dwell meter clipped on to my alternator. I do have the ignition turned to on and I can get an volt reading, just no dwell when turning her over. I get a dwell reading just fine when the engine is running with everything hooked up. Comes in at 23 when I need it at 30. I am using the Actron CP7506 analog meter.
The Tune up sticky says to try the following if Im having this issue:
"If your analog meter needle is pegged up or down, there is a short to ground in the points or condenser wire somewhere or your ignition switch is not turned on. Digital meters will give a zero reading or someway to tell you there is no voltage"
I do have my ignition switch on and dont see a short to ground. Here are some close up pictures of the distributor. Can anyone see anything wrong here?
Thank you for your help.
