johnbottsr
- Oct 6, 2012
- 104
OK, pnwboat helped me out a couple of weeks ago and I was pretty confident my troubles were over, but my motor has failed me yet again.
Here is what happened:
- Launch boat
- Motor starts right up
- idle out of the little cordoned off launch area to the main lake
- apply throttle
- motor dies SUDDENLY
- starter will not turn the flywheel more than an eighth around after this
- get back home and pull the plugs and it will turn over (not seized)
Now, like I said pnwboat helped me out a while back and all the battery connections are clean and tight and the carbs adjusted.
The battery is brand new and charged.
I installed a see-through inline filter between the pumps and carbs and had fuel.
COMPRESSION:
1 - 4 ~ 135 lbs
5 ~ 90 lbs
Last year the motor would stall at cruising speed on occasion but always start right back up.
I am really out of ideas for what this could be so any guesses are welcome.
I was thinking about pulling the head and checking the gasket but if it is possibly something easier to check I would be very happy.
Motor is a 1991J.
- Launch boat
- apply throttle
COMPRESSION:
1 - 4 ~ 135 lbs
5 ~ 90 lbs
Motor is a 1991J.
