eisenpeter
- Jun 13, 2013
- 13
Hi,
I have a 1975 Johnson single lever command controller which controls my 1975 Johnson outboard mtr. I recently replaced the starter solenoid and may have connected wires in wrong place. When I turn the key ON:blue: the motor turns over OK.
The down button brought the motor down but i can't get the up button to work. I cleaned the contacts on the buttons and checked for good electrical connection at the controller handle. Put it back together and still no up movement but down still responds.
The up control button has a black and white wire connected to it while the down button has a black and red wire.
Oh...one other thing. The down button works without the key being turned on. Is that normal ????
Any help/suggestions will be greatly appreciated.
Thank you,
Peter
Thank you,
Peter
