1997 Johnson 115 SPL (Non-VRO)
Starter spins flywheel for a brief couple seconds, then stops altogether. I can spin the flywheel by hand, but it does seem to bind up in a couple areas. Batteries are both good, connections are all good. Replaced both starter and starter solenoid, but the issue persists.
The only thing I can think to do is to put some 2-stroke oil in a spray bottle, remove my spark plugs, and spray a bit in each cylinder. Anyone else have any suggestions? Thanks.
