doghunter9
- Aug 20, 2008
- 101
I have replaced the points and condensers. now I got no spark on the bottom cylinder.
I think I must have a wiring/issue.
1.I have continuity across the two trigger wire to the plug coils with one of the points at the full oppenposition(.020) and the other fully closed.
2. I have a continuity across a individual point when they are open.
3. and it seen I always have continuity to ground from the following parts.
both side of points opened
trigger wires at coils
trigger plate to ground
4. tested the trigger wire disconnected from the points and coil and I don't have a ground so the wire are good.
5 I have the driver coil wires one to each point(is this correct)
Thanks
Thanks
