Hi gurus..
Engine 4.3GXI-B 3869132 serial. 4012077611
Sterndrive DP-SM1.95(M22) 3868913 serial. 4202059888
I got no "beach switch" on the boat, so I can limit the tilt of the outdrive. want to adjust it so I can limit the tilt so it dont hit the bathing platform when I take the boat out of the water. can this be installed or is it already there? and what do I need?
Also got a leak somewhere on the steering cylinder, drips oil in the engine compartment and I also have quite alot of play in the steering wheel, it doesnt get better when the engine is running either. the play is noticable, from 10-2 if you imagine a watch. (new steering wire and steering unit installed 1 week ago)
