I've had no luck with getting these answered.. 1st, I need to know what the broken hose is (red circle) and what it goes to... 2nd, if the starter in the other pic is properly put together?. the bendix will spin up to flywheel when engaged but doesn't drop back down after. is it supposed to always be touching the flywheel??... just don't want to try to start this old motor before i check on those two things.. any help is much appreciated. Thanks!!
