Hey all got a merc 470 that runs ok but has some timing issue also.Using a timing light the engine will not run at the factory timing marks. Check HB timing marks to tbc and the mark on the money so HB has not slip. Its alway 10 degrees off so if a set the timing to run good at idle and starts up good it has no power on take off, and if i set the timing to run good on take off with is advance the dist, its hard to start cause to much timing. New point , condenser ,rotor , wire ,plugs. Has anyone ever had to replace ther dist on a 470 cause of this problem
