trim valve setting help
dzer57
posted earlyier wrong forum
sorry guys
have 470 mercruiser with prestilte tilt trim (square plastic reservior)
had to unstick shuttle valve
have 2700 psi high presure 500 low pressure
issue having is motor cuts out (contact points open wait 30 seconds works again0
motor runs fine with no load
had to guess on turns for relief valves ( forgot ot check before taking apart)
3 valves
2 high pressure (soft valve / bearing)
1 low pressure (bearing)
anyone no correct settings for valves from bottom out
thanks Don
