msd58
- Feb 14, 2003
- 280
Last time out boat spent most of the day anchored. I pulled up drive to to allow for falling tide. Upon departing l lowered drive partially until water depth increased then lowered drive completely. When shifting into for forward it seems to be popping in and out of gear (my best description) and actually felt a pulsation in shifter handle during the symptoms just mentioned. I stopped boat, raised drive to see if there was a visible problem with drive and lowered drive again. It shifted normally and in forward and reverse so I continued on my way. No problems. When I arrived at slip to back into my slip when shifting into reverse the same popping in and out of gear occurred and again I could feel pulsating in shift handle. Drive fluid level normal. Drive pulled at end of last season serviced by reputable firm.
Can anyone comment on this issue?
