Re: New Yamaha F70
My boat is a 1987 center console with a transom cut out for 20" shaft engines. It's set up for twins with two rigging tubes, two fuel ports, and a wide cutout to accommodate the twins.
I troll a lot off shore on Lake Erie. I like the idea of putting half the hours on the engines by running one at a time trolling. I also like the security of having a backup engine all the time. The reason I have a single screw right now is purely because it was all I could afford at the time I got the boat 17 years ago. The rig is underpowered now at half the rated HP (115 HP on a 230 rated boat), which is not the best scenario with a large following sea.
I have a weight issue with the current power I have weighing in at 315#. I don't want to be too heavy in the back and have water coming in thru the scuppers at rest, so I'm trying to keep it light. Right now, my choices seem to be between these 70 hp yammies, and a set of 90 HP E-techs. Unless I'm convinced to go with a large single and a kicker, but I'd need overwhelming reasons to change my mind at this point.
Any thoughts welcomed and thanks for the response!!
