2002 Mercury 150 XR6 Starter Problem
TBEAVER
The starter wheel on my Mercury 150 XR6 stuck in the fly wheel position after the ignition was turned off. The starter got very hot and I had to disconnect the Negative wire. Now the negative sparks whenever I try to reconnect 7 the starter engages even with the ignition off.
Laddies
Banned
Re: 2002 Mercury 150 XR6 Starter Problem
The solenoid is stuck, it needs to be replaced
TBEAVER
Thanks, is this a task that needs a mechanic or can I do it with some clear instructions? Where is the best place to get a new solenoid?
