I have a 40 h.p. 1962 Evinrude selectric motor, 2 cyl. I need to mix my oil with the gas. The motor runs perfect! It starts very easy, and runs great. When it is warmed up, it takes just one revolution of the motor for it to be running. Purrs like a kitten!! Now the problem:
There is gas/oil mixture that leaks out of the front of the carburetor, through the screen attached to the front of it, and leaks (drips occasionally) into the engine compartment, then into the lake, making a beautiful rainbow all around me. If the carburetor is overfilling with gas, shouldn't the motor run bad?? The only thing I ever did so far to try to correct it was to add a gas additive to clean the carb, and the last tankful of gas, I added seafoam to it to try and clean the carb or possibly get the sticking float loose. But again, the motor runs like a new motor but just has this gas leaking out the front of the carb. Anyone know what may be causing this? By the way, I am using a LOT OF GAS because of the leak (I think).
