rebuildnoob
- Jun 10, 2013
- 2
Hi guys, I recently got a free(!) jet boat from a local junk yard. Everything is intact, steering, impeller, etc. However, the motor seems seized.
Lately I've been looking for a cheap or free motor to rebuild and learn on, so it seems this will be the one! I am very excited.
I've done work on car engines and some inboard 4 stroke boat engines before, but have never rebuilt a full engine before, and I'm afraid this is way past my skill level, so I'm turning to you guys for some advice.
I have pulled off the flywheel and stator already: I tried pulling the exhaust, but several of the bolt heads snapped. I know I might have to retap them, and I'm ready for that.
My first question is, what should I do first? Should I unbolt the mounting brackets and pull the engine out of its compartment? I have a room in the house that is empty that I can use for a work room. Should I pull it out of the boat and bring it inside?
I can take pics if you guys need. I am VERY VERY excited for this opportunity to learn! And it's even better since the motor doesn't run; no matter what happens, I can't screw it up worse than it already is!
So what should I do first? Unbolt the mounts and pull it out?
Thank you in advance for any help. I can't wait to get my hands dirty
