Re: Timing On A Trailer
Heres what we do. After the motor is broke in, we verify the timing. In the case of a crossflow like yours, 24 degrees. Make a run, and record RPM. Advance the stop 2 degrees (2 turns) and run again. IF it picks up RPM, then advance it 2 more turns. Recheck. IF it gains, leave it. That should be 28 degrees. If there is no improvement, then we back the stop down the last 2 turns.<br /><br />Also we do the primer trick while testing to make sure the motor isnt too lean in any RPM range.<br /><br />Have fun!
