Realgun
- Jul 31, 2003
- 2,484
I am at the point where I need to pour foam umder the floor.<br />1. I do not want to drill holes.<br />2. The areas are only along the sides of the hull to the stringer.<br /><br />The area is 12 feet long about 6 inches high and slopes to the sides of the boat to 0 inces right at floor boat interface.<br />There are 4 pieces of plywood no longer than 48 inches.<br /><br />If I mix in an 8-12oz plastic cup or a little bigger can I just put the cup in and the screw down the floor then let the foam push the cup toward the open area?<br />I want the foam to support the floor a little and create a good bond to the boat and floor.
