That's the point, Ralph. The minute water hits it, it liquifies (degrades) and flushes out into the bilge. Should future water get underneath the floor, instead of just staying there getting sucked up by the 2 part foam, it will migrate to the open passageways. When I store my boat, I'll leave it bow up with the forward bilge bulkhead plug removed. I guess you might say that I'm using the cornstarch rope in place of wax in the 'lost wax' process.Originally posted by Ralph:<br /> Boomyal - is there no risk of the foam degrading in the presence of water?
Nothing short of a match (or water), will deteriorate it. Solvents don't touch it.Originally posted by cc lancer:<br /> Test a piece of your rope with the foam and see if the heat of the foam disintegrate your rope and you loose your water channels.<br />Hope you don't mind me answering Ralph question,<br />The foam he is using is the best money can buy, it will not absorb water or degrade.
I'll get back to ya on that, starrider.Originally posted by starrider_68:<br /> Very Impressive. Is there a web site to order that stuff or a trade name I can give to a supplyer for that rope? I love the thought put into your rope idea. I dont think anw water will be able to puddle up or in your boat. Good luck with it.
If I'm understanding you, Ralph, that is what the dissolving rope is for. It will just give some clear passageways to allow air in and water out. I made as many passageways in as many places as I thought that water intrusion might get out, should it occur. Being as the rope needed to be anchored, prior to foaming, its placement needed to be along solid surfaces as opposed to trying to create passageways through the middle of the foam. Did that answer your question?Originally posted by Ralph:<br /> Boom - I meant the flotation foam not the rope. Can you create a water channel through the foam?
CC, see the U shape of the rope just aft of the bulkhead? The U is formed from the two lengths of rope running along the bottom sides of the center stringer forward of the bulkhead. There are two holes that the rope come thru.<br /><br />There are also several holes thru the outboard stringers so water can get down to the keel passageway.Originally posted by cc lancer:<br /> How does water get to the bilge in picture #2, will the bulkhead stop it there, didn't see a hole.
My tonque is now sticking out between my lips and flapping rapidly up and down.Originally posted by cc lancer:<br /> Boomyal:<br />Bad news just got of the phone with a Chef, if you corn rope absorbs to much water tonight it may revert back to corn and when the hot floatation foam hits it....well it might start popping........popcorn.
Hey, that's your Queen's own. Schwepps my man. I debated whether to also use the bottles from the other half of that elixer, but I figured it might be bad luck. <br /><br />The bottles in the front center bays are benign apple juice bottles. Didn't wash them out before storing them for future use, so I think the residue has turned to Apple Jack. Yummmm. <br /><br />How's the houseboat roof coming?Originally posted by Dunaruna:<br /> Wouldn't popcorn go perfectly with all that soda he's just drunk?
