870 Expressmag
- Sep 7, 2011
- 154
i had quite a lengthy post on the forum last year regarding this motor and getting it going after i bought it. It was running lean and wouldnt idle and i replaced just about everything ignition and fuel related including thermostat and head gasket. Finally took it to a marina and they adjusted timing and sealed up leaky welch plugs in carb and she runs like a champ...starts very easily...idles very well and runs at full throttle very well....only problem i have is going from a dead stop to full throttle...the motor bogs and takes some time to pick itself up. it's hard to describe beyond that, almost like it's running to rich and then finally leans back out and runs good. it only does it on acceleration from dead stop to full throttle when trying to get on plane to move fishing spots. the high speed jet is fixed in this carb and has a low speed adj but i hate to mess with that since it idles so well. it's a 1969, 18902b. i think i have a video clip of this i will try and post soon.
