Re: Temp Gauge
I have a 1975 Aristocraft with 165hp inline 6. Temp gauge was not working last year so this spring I purchased new sender and new gauge. Also checked continence in wire from sender to gauge and it was fine. Still not getting any readings and I was out today for a long run. Engine getting warm but not overheating and running fine. When I touch wire momentarily to engine block I get a spike in meter when key is in on position. So whats my next move? Could it be a bad ground to meter?
A few questions.......
Did you remove the thermostat housing?
If you did, did you use the bottom gasket with the rivets when replaced (if not, you probably have a bad ground to the housing from the manifold)?
Did you use silicon sealer on the new gasket (this will prevent a good ground sometimes. Don't use silicon on that bottom gasket with the rivets)?
When you installed the sender into the housing, did you use teflon tape or silicon sealer to seal it (if you did, the teflon tape can / silicon insulate the sender from the housing)? Just use a small dab of regular gasket sealer or pipe dope (not silicon), if need be.
If you get the meter to peg when grounding the sense wire to the block, I would venture to say meter wiring is good. Betting on the sender not being grounded properly.
