Gordon88
- Jun 19, 2012
- 17
Hello,
Okay so i bought this 1990 302 ford car eng. to swap out of a 1977 cobalt, the issues i have ran into are harmonic balancer, distributor, flywheel/flexplate, and serpintine belt to v belt.
The distributors i have have under control for most part any extra info could be helpful. What i have tried to do is take an older motor with flat tap lifters and such and have tried converting the parts needed on to the 1990 302 block with the roller can and lifters, everything was going smooth until i noticed the harmonic balancers were different from eachother and the 1970's model will not work on the 1990s so i looked into just making the v pulley fit the 1990s balancer and it causes the pulley to be out of alignment with the rest, also the older model is 3bolt the earlier model is 4bolt pulley.
And i was also needing info for the flex plate, would it work on the 1990 302 or am i going to have to buy another?
"I was under the influence that the intake, carb, and distributor would be the only things different"
