CRAIGSBOAT
- Jun 7, 2013
- 4
I have a 1996 120hp Force outboard. The stator went bad with a carmel looking substance oozing from the top and side of the stator. When I wne to take the flywheel off, I took the nut off that holds the flywheel on, I noticed there was a crack running vertically down the crankshaft from the top about 3/4 inches long. The cack stops above the part of the crankshaft that holds the flywheel.
Has anyone encounterd this before? Would anyone know if this will cause a problem and continue to crack farther down the crankshaft? I hate to have to replace the crankshaft or get a rebuilt powerhead because I don't want to put that kind of money into a boat that isn't worth anything. Any thoughts and insight would be appreciated.
