Re: Was plywood a good choice for floor repair???
Just to offer a different stance on redoing the boat, as opposed to letting it get worse and getting rid of it. I redid a $500 15-foot Starcraft a few years ago and loved the experience. I installed new stringers, floor, seats, etc. and spent about $1100. BUT, when I was done, I had essentially a brand new boat. In the restoration process, I installed new steering helm, new wiring, new light fixtures, etc. Everything that could possibly break, fall off or wear through had been replaced. Try finding a brand new 15-foot runabout with trailer for the total of $1600! It ain't gonna happen.<br /><br />The only downside of the first project was that I can do all sorts of glass work, as long as you can't actually see the results, and the boat had some external cosmetic issues that I wasn't ready to deal with - so I bought another, cosmetically cleaner project boat to redo for this winter! I plan on taking some of my experience from the first go-round and improving the new boat in the process. The boats are literally BETTER than new (structurally speaking), as I am using West System where they originally used poly resin to bond glass to wooden stringers, etc. The boat will be stiffer, lighter and faster than original! I'll be using modern closed-cell foam for flotation, replacing the older, saturation prone foam. I'll be using better materials all around and the boat will be set-up the way I want it when I'm done. <br /><br />Bottom line is that redoing a boat isn't for everyone, but if you have the space and can afford the time, it can be well worth the effort.<br /><br />- Scott<br />
http://www.pfs-ware.com/smith
