I have a 1989 Mercury 115hp inline 6-cylinder and I have trouble when trying to take off the engine feels like its going to stall and will at times. I have replace all the main fuel lines coming to the disconnect, fuel filter and primer bulb. It seems as if it won't stay primed when connected to the engine. I can pull the line off the disconnect and can prime it with my finger over the end or if I put a hand pump on the end of the line it will prime and fuel will stream out until I close the tank ball valves off. I have checked the intake pickup lines and they are fine. I am suspecting its either a fuel pump issue or a disconnect issue. Wondering if anyone else has experienced this and what should I do. It will start and run ok in neutral I can rev it up and everything just fine. I put new gas in after dumping the old out and cleaned the tanks. I used a 50:1 ratio on the fuel to oil and I even put seafoam in the fuel as a treatment. I Think this is the fuel pump I have not sure http://www.crowleymarine.com/mercury-outboard/parts/278_12.cfm Please help!
Thanks,
Jason
Thanks,
Jason
