Re: Water in Engine compartment
Does that model have any coolers that are known to drain into the bilge that might explain it?
If not, time to start figuring out where it's coming from as it could mean some repairs are needed before the condition gets really bad.
I assume you trailer the boat so may start with making sure the bilge is completely dry, put the drain plug in and run it on muffs.
See if you're getting any water coming from the engine simply running under no load. If water is being left that way, try and get in there with a flashlight and your eyes to see where it's coming from.
Another thing to try is raising the front of the boat up on the trailer as high as possible, again with the drain plug in, then using a garden hose put water in the bilge and see from the outside if you find any coming out.
Can also back the boat into the water and leave it on the trailer and see if any water is getting in from just sitting there.
If you have a swim platform, any screws/bolts and also fatigue and may need to be sealed again.
Mark
