Check out my CD-10 that I bought for $100 off craigslist. I was told it was told it was in good working condition. It turned over and felt like it had compression so I bought it. After getting it home I replaced coils, points, condensers, wires, impeller, carb Kit, plugs, and power head gasket. After seeing it had nice blue spark I put it in the test tank. (I forgot to check compression). Tried to pull over but it would not turn even with starter off. I then pulled the head off, you know its not a good sign when you can pull the bottom piston out. Here is what I found. I am going to rebuild it, and ordered rings, connecting rod, and new gaskets and seals.
ONFIG]197575[/ATTACH]
