soggy_feet
- Oct 10, 2009
- 713
Mercruiser service manual says for the 165hp engine, with a RPM spec of 3900-4300 I'd want a 16", 11 pitch, 3 bladed prop.
Under the "approx boat length" I fall under "houseboat", and it is a houseboat. Next column is speed range, listing 10-18mph
Row above is 30'+ 16-24mph, (I'm probably 36ft at waterline)
Row below is "work boat", 1-11mph.
Now, whether it's because it wasn't propped right originally, or because the engine is tired, I can't turn more than 3,600 RPM's, and doing that in ideal conditions I can just hit 10mph.
A few more specs on my boat-
LOA:38'
Beam: 11'
Approx weight: 15,000lbs
The workboat row lists a 16", 9 Pitch, 3 blade prop for the listed 1-11mph.
My understanding of all this tells me I should probably go with a lower pitch prop so the engine isn't straining so hard, but at the same time, I'd really rather not loose any more speed.
The lower pitch should let me gain back some revs, which should counteract the fact that I'm taking less of a bite I'm assuming. Should I expect to see an increase in range/speed with the lower pitch?
What about moving to a 4 blade prop?
Thanks for the help
LOA:38'
Beam: 11'
Thanks for the help
