flounder920
- May 13, 2013
- 6
Hi all,
I have a 1996 Cobia 19 foot. It's been completely reworked, inside and out. Looks and runs excellent (1996 Yamaha 115 2 stroke). I've had it for about a year and the previous owner did all of the work on it. He's a good guy and has been restoring boats for a long time.
One of the things he did was redo the inside with Awlcraft 2000 topped with a light blue non skid surface. Around the captains chairs / cooler is a definite rectangle, almost silouhette, which are obviously 2x4's that were used as support for what I am guessing is for the gas tank that he replaced.
The non-skid floor is VERY slightly cracking around these support beams. I've even noticed a very small (2 inch x 2 inch) very slight soft spot. On one of these "cracks" in the non-skid pad.
It's barely noticeable and only by me - no one else even notices any of this, but I do and need to make sure it's not going to develop into a bigger problem. The bilge area stays almost entirely and although the boat does seem heavy, I've been told that this is a heavy boat to begin with. It runs great and holds up very well in tougher seas.
Could this be a bigger problem, or is there anything I need to do in the meantime? I've been told his support structure wasn't put in exactly right, but I shouldn't have a problem.
Any ideas?? I can post pictures if that helps!
