Olias
- May 28, 2013
- 99
I have a 12' Starcraft Alum. boat that I just recently started using a 96' Mercury 8hp motor with. The motor is more than enough power for what I use it for but at 1/2 to full throttle the nose of the boat sticks WAY up in the air. Looks silly. I have tried re-arranging things a bit putting the 6 gal. fuel tank more towards the middle of the boat etc., but it still will not plane out worth a beans. I was/am considering buying this motor but if I can't get this figured out it's a no go. I'm aware of the 3 different tilt angles it has but adjusting to any of them only makes it worse. It's almost like it needs to tilt in more (towards the transom) to kick the nose down, but of course it can't angle forward any more. Currently it's straight up and down flush with the transom. Is it possible it needs a different type of prop? I've heard there a different styles like for speed, power, etc. Any thoughts? Thanks
