Franky4Boats
- May 29, 2012
- 12
New Impeller, Thermostat and Thremostat Housing, Transom to pump hose, Risers / Manifolds and even the circukating pump, the water is flowing.
My engine sounds like it runs and it runs perfect, what could make it run up to 225 as soon as I hit it? It get hot slow continuously and cools off at the same rate. Unless I put it into neutral and run it up to like 1000 to 1500 and then it cools much faster. When I first start it it heats up much faster in the slip than the other motor and the risers get hotter faster.
