Re: 1967 Evinrude 6hp Lower Unit Removal
Q: is there a serial number plate on the side of the transom clamp?
I'm thinking there are a couple of possibilities here: either you've got an older lower unit off a 5-1/2 hp, or someone has been playing mix-n-match with the rest of the motor. The cowling and cover look correct for a '67, and the center section, from what I can see of it, has paint which matches the cowl and powerhead.
The lower unit looks like it was re-sprayed and you can see the darker blue original paint underneath.
Probably from a much older Evinrude. If it was from a 5-1/2hp, it would have had a longer shift rod.
It's possible to retrofit an earlier lower unit to a 6hp, since it'll bolt right up. But they would have had to remove the powerhead to do so, since the only disconnect for the shift rod is at the clevis on the end of the shift lever.
Looks like you'll need to remove the powerhead to gain access to the shift linkage. What fun! At least it's not extremely complicated on this motor.
I found a Youtube video of a guy doing pump R&R on a small twin, it should help you get an idea of what you're in for:
Dropping the Lower Unit on mid 50's 5.5 and 7.5 Johnsons and Evinrudes - YouTube
You're gonna need a powerhead gasket. There's an O-ring for the quad seal (lower crank seal) as well, and a cork gasket for the seal plate. These are consumables that should be replaced any time the motor's been taken apart; they're inexpensive and readily available.
The good news is, someone has retrofitted the later-style plastic pump, which has a stainless insert. This is a more durable pump, as the old aluminum pump housings tend to rot away after many years. It'll pump a lot more water, too.
So, when you look up part numbers, be sure to get the later-style impeller which goes with the pump kit. If you go by the part number on the old diagram, it'll be the wrong impeller.
Check out this diagram and the notes for the impeller, part #16 on the diagram:
Johnson Gearcase Group Parts for 1967 6hp CD-24 Outboard Motor
This is for a '67 6hp Johnson, the parts will be the same as for your Evinrude.
Here's a link to the center section, so you can look up gaskets etc:
Johnson Lower Unit Group Parts for 1967 6hp CD-24 Outboard Motor
HTH.............ed
