Blacksting
- Aug 15, 2011
- 213
I thought I had an empty gas tank , so I poured 2 gallons of fresh gas , tried starting her up , no dice . Long story short , I finally took off the carb and there it was , water , and lots of it . pulled the gas gauge pick up off and the 18 gallon tank was full of water .
I pumped out the water , pulled the tank out , added some alcohol , swished it around and dumped it . pulled the plugs , and with a bottle on the fuel pump line , cranked the engine and pumped out about 20 ounces of water . I blew out any and all ports and lines w/ compressed air .
I put everything back and could only get a few 'coughs' out of her with starter spray . ,...............what now ? ,.....is there still water inside the block/combustion chambers ?
