Guys I have an 89 Avanti I'm restoring and after I popped the cap I came into the problem of how to get the wiring out of the bottom of the boat. It's ran through a 1/2" ply with thin glass top channel molded into the deck and side of the hull. I put some pictures up. I'm cutting out the deck due to rot and the only way I can see to get the wiring out of the bottom of the boat and pulled up with the cap so I can cut is to cut through the channel. Any suggestions?
