imported_bowfisher
- Jul 17, 2006
- 73
All,
I have a 50hp Force throwing a fit. Intermittent spark at best.
Pulled plugs, grounded them to the block, hit the key and cranked it over, after cranking for a few seconds the plugs sparked then quit.
Cranked again, nothing
Cranked briefly another 4 times - no spark
Cranked it the 5th time and the plugs sparked bright blue spark perfectly.
Installed the plugs, hit the key, motor fired up then I shut it off to resume diagnosis.
Pulled plugs, grounded then cranked the starter, no spark
This is where I am currently at with it, no spark or intermitent spark.
Thoughts on this one? Key switch? Loose ground wire (have not found one yet)? Bad coil under the flywheel? I cant imagine the CDI is all bad at one time.
Thanks!!
Thanks!!
