brnschoneck
- Feb 22, 2013
- 337
While im having this bog down prob... i replaced my throttle cable as it was all shot becouse the motor did not respond until i had it pulled up about half-way is this right ??? also then when i put it in f , after it goes into gear right away but i have to push a little further maybe a inch before it start to accelerate ??? I adjusted it at motor to put a lil preassure on idle stop screw but how do I adjust the pull , im assuming something is controll box is shot but idk i cleaned it all up and greased it what should i try to do next ???? It has the balls on both ends with the little key slot at motor ????
