77americaneagle
- May 23, 2013
- 34
Hi everyone. Just replaced fuel pump and filter and canister. When I put the canister on I filled it with gas. I poured a little gas in the carb and it started and ran for a few minutes and then I shut it down ( had water going to it). I had a leak in the fuel line from the pump to the carb and replaced it. Now it won't run again. I checked the filter canister and it was only 3/4 full not enough to go to the pump. Upset so I covered everything up for the night and take a break (and a beer) Tomorrow I will take my 2 gal gas can, go buy a rubber fuel hose and see if it sucks that way and runs. Any other things I should look for?
