Hillbilly Yat
- Jun 4, 2013
- 5
Does any one know what causes this.Engine runs fine with collars on. I am new at this so you can see.
How does it run on the water ??
Collars? If you're speaking of running the engine by using a flushette, have the water turned on full force (high hp engine).
Check the compression. What are the readings of all cylinders?
