clayspivey
- Jun 5, 2013
- 4
10 years ago I traded a 10 foot boat for a 1959 evinrude lark 35 hp in great shape, but not running. We put some new coils on it, and I was off the the lake. At the time I knew not what I was doing and haven't seem to learned anything since. The motor ran and stopped ... on and on. I parked it and went to college.
It sat in the barn for 10 years till a storm blew the barn down. After ten years a week ago it started right up and ran fairly well, but I need to fix the problems it has with not running well .
So I replaced the thermostat, Carb Kit, fuel pump Kit, lower unit, IMPELLER which was in horrible shape and most likely causing my problems ...
I must have screwed up the carb float, now the motor wont run at all. I think it might be flooding.
The new kit came with a needle and float with a clip that I believe clips the needle to the float...... I just don't know much about it.
I bent the small brass piece on the float to about the same position as the float I took off. I thought the float was level with what I read on the internet that it should be.
How much fuel should go through the fuel pump while I have the hose off and am cranking the motor with the electric start?
I made it worse!
I
I made it worse!
I
